ARC Raiders Items can become useful during many different activities, but some quests are more about careful exploration than collecting valuable gear. “Keeping the Memory,” given by the trader Celeste, is a good example. The quest sends you into the Dam Battlegrounds map to find an old First Wave robot wreckage, recover a missing soldier’s helmet, and restore a small memorial. Because all three main objectives must be completed during one raid, preparation and awareness are especially important. A mistake that sends you back to the lobby before the objectives are finished means starting the quest sequence again.
Understand the Quest Before Deploying
The first thing to remember is that “Keeping the Memory” has three connected objectives. You need to reach the wreckage in the Formicai Hills, search for the missing helmet, and place that helmet on the nearby memorial stake. These steps are close together, which makes the quest relatively straightforward once you know where to look. The main challenge is reaching the location safely and avoiding an unnecessary knockout before the objectives are complete.
Since the quest takes place in Dam Battlegrounds, check your loadout before entering the raid. You do not necessarily need an expensive setup. A practical weapon, enough ammunition, healing supplies, and room for the quest item are generally more important. The helmet must be physically picked up after searching for it, so keeping some inventory space available can prevent an awkward situation.
Head Toward Formicai Hills
After deploying into Dam Battlegrounds, make your guay toward the southeastern part of the map. Your destination is The Wreckage in the Formicai Hills, positioned just east of the Scrapyard and Formicai Outpost. Using these nearby landmarks can make navigation easier, especially if you are still learning the map.
As you approach the area, look for the enormous rusted Baron ARC husk. Its spider-like shape makes it stand out from the surrounding environment. Reaching the wreckage is enough to trigger the first objective. Once the quest recognizes your arrival, you can focus entirely on finding the helmet.
It is worth slowing down once you reach the area. Other players may also be moving through the same region, and rushing directly toward the objective can leave you exposed. Take a moment to check your surroundings before interacting with anything.
Search the Ruined Machine
The missing helmet is not sitting openly in the middle of the wreckage. Instead, you need to inspect the north side of the ruined Baron machine. Look around the base of the structure for a small bush or unusual-looking plant. This detail can be easy to overlook if you are concentrating on the much larger machine.
Approach the plant and hold the required interact button. A search timer will appear, so remain nearby until the interaction finishes. The helmet will then drop onto the ground. This is an important part of the quest because searching alone does not finish the objective. You must physically collect the helmet and place it in your inventory.
Before moving away, confirm that the helmet is actually with you. This simple check can save time and prevent confusion later.
Restore the Memorial
After collecting the helmet, move only a short distance from the bush. Look for a metal pole or stake sticking out of the ground near the wreckage. When you approach it while carrying the helmet, a blue holographic helmet prompt should appear.
Interact with the pole to place the helmet on the memorial. Once this happens, the quest objective is completed. Unlike the earlier steps, you do not need to carry the item any farther after the placement.
Finish the Raid Carefully
Once the memorial has been restored, you have more flexibility. You can immediately travel to an extraction point, such as the Red Lakes Balcony Lift to the northeast, if your priority is completing the quest safely. Alternatively, you can remain in the raid and continue collecting resources.
The key difference is that the quest is considered complete after the helmet is successfully placed. If you are knocked out afterward, the completed objective will still count. Before that moment, however, getting knocked out resets the quest progress, so cautious movement is worthwhile.
Complete the Quest and Collect Your Rewards
Return to Celeste in Speranza after successfully completing the memorial. The quest rewards include 5 Simple Gun Parts, 5 Duct Tape, and 5 Magnets. These materials can make the trip worthwhile while also giving you a reason to learn the Formicai Hills area.
For players looking for ARC Raiders BluePrints for sale, understanding efficient quest routes can also make broader progression easier. Keeping the Memory itself is not a blueprint mission, but learning the map, extraction routes, and safe movement habits can help with future objectives that require more valuable rewards.
If your main goal is to buy ARC Raiders Bps, completing simple quests like this can still contribute to a stronger overall routine. More importantly, the quest teaches you to follow environmental clues instead of relying entirely on obvious markers, which is a useful skill throughout Dam Battlegrounds.
