• RSVSR Tips Happpies 10 new supercars make GTA 5 Enhanced pop
 #630412  por Hartmann846
A lot of folks assume GTA 5 on PC has nothing left to surprise them, especially if they mostly play story mode and only jump online now and then to grind GTA 5 Money. But a modder called Happpie has just proved that idea wrong. They've released a new vehicle pack for the enhanced version that adds ten original supercars, and it doesn't feel like the usual "close enough" add-on you uninstall a week later. You can tell it was made by someone who actually drives around Los Santos and cares how a car sits in traffic, how it looks under harsh sunlight, and how it behaves when you clip a curb at speed.
Built like they belong in Los Santos
The biggest thing you notice is that these aren't ripped models wearing a quick paint job. The shapes feel like GTA designs: bold, a bit exaggerated, but still believable. Interiors aren't an afterthought either. You get proper dashboards, readable dials, and seating that doesn't look like a plastic shell. The geometry is clean, the textures are sharp without being heavy, and the LOD work is done right, so you're not tanking performance just because you're flying past Vinewood at 120. That's the sort of unglamorous work most packs skip, and it's why this one feels "official" in motion, not just in screenshots.
Handling that doesn't fight the game
A lot of custom cars look great, then you take a corner and the whole illusion falls apart. Here, the handling sits in that familiar GTA middle ground. It's got weight and bite, but it still lets you throw the car around without feeling like you've installed a hardcore sim. You'll feel the difference between a planted, grip-heavy build and something twitchier, yet it never turns into a physics experiment. If you're used to top-end GTA Online machines, these fit right in—quick launches, strong braking, and that satisfying sense that you're always one mistake away from turning the thing into scrap.
Stability, spawns, and day-to-day mod life
If you've ever run a busy mod list, you know the real test is whether the game stays up for more than an hour. Happpie's pack seems built with that reality in mind. The cars behave like vanilla vehicles, slot neatly into the world, and even show up in AI traffic without causing chaos. That matters more than people admit. It means you're not babysitting your install, not dealing with random crashes after a mission, and not hunting through folders trying to figure out which add-on broke your save.
Why this drop actually matters
Rockstar's attention is still pointed firmly at GTA Online, so single-player fans live off what the community makes. Packs like this keep the map feeling fresh without rewriting the whole game. Ten good cars can change your whole routine—new cruising spots, new chase energy, new reasons to revisit old roads. And if you're the type who likes switching between modded story mode and online progress, it's easy to see why people look for shortcuts and options like cheap GTA 5 Money while still coming back to these offline upgrades for the pure driving feel.
