Página 1 de 3
suspensiones q os parece
MensajePublicado:27 May 2008, 14:03
por sergio_rs6
q os parece esta suspension? tiene buena pinta no por 350¤
This is a Gaz adjustable suspension kit for Peugeot 106 all models (1991 +) and Citroen Saxo 1996 onwards.
The kit has two front adjustable damping inserts, two rear adjustable dampers and two front -40mm lowering springs.
Every Gaz unit is fully tested and dispatched with an individual dynometer report.
Made to accredited ISO9001 standard and supplied with a 2 year unlimited mileage warranty.
Gazzmatic International Ltd. are a TUV approved company.
Gaz shock absorbers strike the ultimate balance between comfort and performance roadholding.
Ideal for fast road or track day use.
Gaz shock absorbers guarantee to improve the looks and handling of your car.
Fully rebuildable and servicable.
Gaz units are provided with an on car multi point adjustment facility that alters bump and rebound settings by a single control knob on the side of the unit. The inserts are fitted with a top adjuster that alters rebound settings only.
They have zinc plated bodies for maximum protection against corrosion.
Made in England.
y tambien e esacontrado esta Pues 250 mas portes, tiene cantidad por si alguein quiere.
http://my.frooition.com/070481/images/U ... gshop2.jpg
HOTTUNING FULL COIL OVER KIT
WITH A 2 YEARS WARRANTY
This is a full coilover kit for the front and rear of your vehicle. Kit will fit:
COIL OVER CITROEN SAXO ALLE ENGINE
2 X FRONT SHOCK ABSORBER AND 2X ADJUSTABLE SPRINGS REAR 2X SHOCKABSORBER AND THE TORSION BAR YOU CAN ADJUST YOURSELFS
Coilover Specifications:
HOTTUNING coilovers can be raised or lowered, from 20mm to 80mm. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. CNC Wound SAE 9254 Racing Springs are used which were found to be the longest lasting spring on the market that showed no tendencies to sag. Spring and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability are used. Extensive Research And Development Went In To Choosing Precisely Matched Spring & Damper Rates Specific To Each Application. The Result Is Outstanding Ride Quality & Incredible Handling Characteristics
This Kit Includes - 2x FRONT COILOVERS 2x REAR COILOVERS/SPRING ADJUSTERS 1x C-SPANNER
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. HOTTUNING , Designed and manufactured for customers who demand the very best!
FAQ:
Is this a complete kit?
Yes this is a complete suspension kit for all four corners of the car
Does this fit my vehicle?
This kit will fit the vehicle listed in the first table above.
Is there a Guarantee?
Yes. This kit is covered by the manufacturer for two years.
What kind of quality is this kit?
This kit is of comparable quality to units offered by Gmax, Pi, FK, Weitec and Jamex. The shocks are approx 30% uprated over standard.
You can get more info on our website or email us
Only SERIOUS BUYERS PLEASE. Only buy you intend to complete the transaction.
FEEL FREE TO CHECK OUT OUR FEEDBACK!! OUR CUSTOMER SERVICE IS #1!!
Check out Our Ebay Store for more suspension/performance components for your vehicle!
RE: suspensiones q os parece
MensajePublicado:27 May 2008, 14:04
Compra algo con homologacion española que despues vienen los lios .
MensajePublicado:27 May 2008, 14:11
por sergio_rs6
pero tu crees q se lo miraran...
esque hay mucha diferencia de precio davish, porque montas unos pts y te dejas 600 con muelles sabes...
esque ayer estuve en asv aqui en barcelona y me dijeron que me retaraban los de serie si queria y ponia los muelles por 400 euros.
es un poco caro creo...
porque me dijo que con eibach y susp de serie me trabajaria solo el muelle q la suspensione en curbas aria tope... y no se
es una locura esto jejeej...
MensajePublicado:27 May 2008, 14:34
por PTS
ombre depende quien tare las de serie.... conozco gente que prefiere unos de serie tarados y no unos pts.. pero eso para gustos.... seguro q alguien lo conoce pero por el pais vasco ay un señor q se dedica a acer esas cosas y sabe bastante de ese tema VITORINO SPORT
MensajePublicado:27 May 2008, 15:06
por Jesus_VTSGRA
En mi opinion si lo que quieres es bajar el coche y darle un uso de ciudad y sin andar de tramos mete lo ams barato, tipo KW, LIP..., pero si quieres algo que valla bien no te andes con medias, mete PTS, sino luego te arrepentiras :wink:
MensajePublicado:27 May 2008, 15:10
yo he cambiado hoy y he metido lip sport con eibach, va perfecto el pequeñin.
MensajePublicado:27 May 2008, 15:17
por FoX
lip sport con eibach?todo esto te viene con papel de homologacion?¿¿? porque me interesarias saberlo si quieres mandarme lo que te ha costado i todos los detalles por mp te lo agradeceria mucho davish!un salu2 i gracias
PD:SERGIO no te fies
MensajePublicado:27 May 2008, 15:28
Los eibach fueron los primeros en tener homologacion española y de esto hace unos cuantos muchos años.
MensajePublicado:27 May 2008, 18:03
Creo que por lo que decis no sabeis que los PTS son los de calle retarados por peugeot sport...Peugeot Talbot Sport
MensajePublicado:27 May 2008, 20:52
por PTS
rocha los pts no son de calle retarados por peugeot sport... ya m elo han dicho varias veces pero puedo asegurar al 100% q no son retarados por peugeot sport...
MensajePublicado:27 May 2008, 21:20
entonces por quien?
MensajePublicado:27 May 2008, 21:25
por PTS
pues por peugeot sport pero no de serie una cosa es quien haga los amortiguadores y otra q sean de saxo retarados..
MensajePublicado:27 May 2008, 21:27
explicate que no acabo de entenderte.
MensajePublicado:27 May 2008, 21:31
por PTS
que es lo q no acabas de entender?? ya hemos discutido una vez este tema yo sigo en las mias y tu en las tuyas...
un vecino tuyo o de la zona el nombre no voy a nombrar es un preparador muy conocido el cual le trae el material directamente de puegeot spor a mi amigo, y los pts no son de calle retarados.. y si tu crees q si pues lo dejamos ahi q no pasa nada.. un saludo
por Serfe
PTS me da que te has echo un pelín de lío al leer la contestación de Rocha....
MensajePublicado:27 May 2008, 21:32
por PTS
serfe no me he liado nada...
MensajePublicado:27 May 2008, 21:36
Tu eres familiar de N@ughtyBoy ?
por FoX
jajaja vaya lio!xD
MensajePublicado:27 May 2008, 21:38
por FoX
jajaja vaya lio!xD
MensajePublicado:27 May 2008, 21:42
por PTS
para nada.. el es de santiago y yo de ferrol y ademas tampoco te tendria q importar lo q pasa q no dejais q alguien lleve la contraria.. pero buenooo
