eld.gg MLB The Show 25 Stubs: Break and Depth
MensajePublicado:13 Ago 2025, 05:27
por Kongyawen
Practice for Pitch Recognition in MLB The Show 25
Hitting in MLB The Show 25 is as much about seeing the ball as MLB The Show 25 Stubs it is about timing your swing. Pitch recognition—the ability to identify the pitch type, location, and potential movement as quickly as possible—is the skill that separates casual hitters from elite ones. You can have perfect mechanics and still fail if you can’t spot a slider breaking out of the zone or a high fastball screaming by. This guide breaks down why pitch recognition is crucial, how to train it, and the in-game tools you can use to master it.
Why Pitch Recognition Matters
In MLB The Show 25, reaction time is short—especially on higher difficulties like Hall of Fame or Legend. You have fractions of a second to read:
Velocity – Is it a 99 mph fastball or an 83 mph changeup?
Movement – Is the ball cutting in, breaking down, or staying straight?
Location – Is it in your PCI range or is it going to dart outside the strike zone?
The better you recognize pitches, the more confident you’ll be in your swing decisions. This leads to:
More walks (avoiding swinging at junk)
More hard contact (attacking only hittable pitches)
Fewer strikeouts
Better control over the count
The Foundations of Pitch Recognition
Before we get into drills, you need to set up the best environment to train:
Use a clean, bright batting camera that gives you a good view of the pitcher’s release point. Zoomed or offset angles help spot breaking balls.
Adjust pitch speeds in custom practice to slightly above what you’re comfortable with—this makes real games feel slower.
Focus on release point and hand position rather than following the ball halfway to the plate. Elite players start reading pitches at release, not mid-flight.
Three Core Skills You Need to Develop
1. Reading the Release Point
Every pitch starts with the pitcher’s hand position. Learn to recognize:
High release → possible fastball or overhand curve
Low release → possible changeup or sidearm delivery
Wrist angle → breaking ball or off-speed
The earlier you identify the general pitch family, the faster you can decide to swing or hold.
2. Tracking Spin
The game’s ball-spin visuals are subtle but readable if you train your eyes:
Fastball – Tight backspin, ball looks “clean” coming in.
Slider – Tilted spin, may have a slight red-dot effect.
Curveball – Forward spin, ball seems to drop out of the hand.
Changeup – Slower spin, may appear to “float” toward the plate.
3. Recognizing Break and Depth
After release, pick up whether the ball is holding its line or moving:
Early vertical drop → curve or splitter
Late horizontal sweep → slider or cutter
No movement but cheap MLB Stubs slower speed → changeup
