• U4GM Where to Build the Best Black Ops 7 Beta Class
 #630414  por Hartmann846
I jumped into the Black Ops 7 multiplayer beta thinking I'd mess around for an hour, then log off. Yeah, that didn't happen. The new Create-a-Class setup has me tinkering between matches, shaving off little mistakes, swapping one thing, then swapping it back. If you're the type who likes testing builds or warming up in a CoD BO7 Bot Lobby, you'll get why this system feels so good: it lets you chase that "this is my loadout" feeling without forcing you into one boring meta path.
Weapons that actually feel distinct
The early weapon pool is already doing a lot of the heavy lifting. Assault rifles are the comfy home base: MS MOD 0, PEQ, and MXN-17 are steady, but the Peacekeeper MK1 and GRAZ 45K are the ones that keep pulling me back in. They're quick enough up close, but they don't fall apart the second a fight stretches out. SMGs are pure chaos in the best guay—DRAVEC 4S and RAZOR 9MM are made for doorways, stairwells, and panic sprays that somehow work. If you'd rather anchor a lane, MK 78 and MRA1 LMGs can bully people off headies. And for those mid-range picks, the VS RECON marksman rifle snaps onto targets fast without feeling sluggish.
Secondaries, Wildcards, and the "save me" moments
Your sidearm matters more than folks wanna admit. The JAGER 4S, CODA 9, and A.R.C. M1 all hit hard enough to bail you out when your mag's empty and someone's still flying at you. I've also run into plenty of FLATLINI users doing the quiet flank thing—no warning, just gone. Wildcards being back is the real kicker, though. Overkill is the obvious pick when you want an AR plus an SMG and don't wanna compromise, but Prepped and Perk Greed keep tempting me when I'm building around utility instead of raw gunfights.
Perks and Combat Specialties change how you move
This new Combat Specialty idea is where the beta starts to feel different from "same CoD, new coat of paint." You're still picking perks across three slots—Perk 1 options like Tech Mask, Cold-Blooded, Dexterity; Perk 2 stuff like Scavenger or Tracker; then Perk 3 with choices like Vigilance or Hunter's Instinct. The twist is lining them up by category to trigger a Specialty. Enforcer, Recon, Tactician, Scout, Operative, Strategist—each one nudges you into a role and actually pays you back for sticking to it. Pair that with Field Upgrades like Active Camo, Trophy System, Assault Pack, Squad Link, or Drone Pod, and you'll notice teams winning off smart setups, not just cracked aim. If you're trying to dial in your approach before hopping into tougher lobbies, running a few focused tests in buy CoD BO7 Bot Lobby can help you feel those Specialty bonuses click in real time, especially when you're tweaking one perk at a time.
