• Mmoexp Path of Exile 2: Ice Shot Amazon Build Guide
 #630423  por Kongyawen
PoE 2 Patch 0.4 Ice Shot Amazon Build Guide: Leveling, Skills, and Endgame Setup
If you're searching for a powerful ranged build in Path of Exile 2 that isn't Lightning Arrow, the Ice Shot Amazon stands out as one of Path of Exile 2 Currency the strongest alternatives in patch 0.4. While it shares a familiar playstyle with Lightning Arrow, Ice Shot offers a distinct identity built around Freeze mechanics, shatter explosions, and devastating boss burst windows.
This build uses the Amazon Ascendancy for the Huntress, leveraging high Critical Strike scaling, exceptional mobility, and the unique Reveal Weakness mechanic. Reveal Weakness allows Amazons to deal increased damage to Rare and Unique enemies, making Ice Shot Amazon exceptionally strong in endgame mapping and boss encounters.
Leveling an Ice Shot Amazon in Path of Exile 2
Ice Shot is not available early in the campaign, so efficient leveling requires a bow setup that shares scaling with the final build. The best option by far is the Lightning Arrow + Lightning Rod combination.
Recommended Leveling Setup
Drop Lightning Rod on enemy packs
Fire Lightning Arrow through enemies to trigger fast chain clears
This approach is simple, effective, and beginner-friendly. More importantly, both skills scale with projectile damage, elemental damage, attack speed, and critical strikes, which directly benefit Ice Shot later.
If you've played Lightning Arrow before, the transition will feel seamless.
Once you obtain a level 9 Uncut Skill Gem, you can swap to Ice Shot. At this point:
Remove lightning-specific passive nodes
Invest into Cold Damage, Freeze chance, and Cold Penetration
Keep projectile, crit, attack speed, and movement nodes unchanged
This minimizes respec costs and keeps progression smooth.
Ice Shot Amazon Skill Setup (Endgame)
After finishing the campaign and entering maps, your Ice Shot Amazon skill setup should be fully online.
Main Skills
Ice Shot: Elemental Armament - Cold Penetration - Frost Nexus - Fork
Herald of Ice: Cold Penetration - Deadly Herald - Cold Attunement - Overreach
Ice Shot handles clear speed, while Herald of Ice enables massive shatter chains that wipe entire packs instantly.
Utility and Single-Target Skills
Freezing Salvo: Freeze - Concentrated Area - Ice Bite
Snipe: Window of Opportunity - Concentrated Area - Close Combat - Inexorable Critical
Ball Lightning: Shock - Blind - Considered Casting
Freezing Mark: Prolonged Duration
Barrage: Cooldown Recovery
Despite the number of skills, you won't use everything at once-each has a specific role.
Ice Shot Amazon Combat Rotations
Mapping and Clear Speed
Spam Ice Shot to freeze packs
Herald of Ice shatters frozen enemies
Fork provides wide coverage and consistent screen clears
This results in fast, fluid mapping with excellent crowd control.
Rare and Elite Enemies
Apply Freezing Mark
Shock enemies using Ball Lightning
Finish with Ice Shot for amplified damage
Bossing Rotation
Apply Freezing Mark
Shock the boss with Ball Lightning
Use Freezing Salvo to trigger Freeze
Activate Barrage
Channel Snipe during the Freeze window
With proper gear and crit scaling, bosses can be deleted in a single damage phase.
Ball Lightning is optional, but Shock significantly increases damage taken in Path of Exile 2. Many players run it on a secondary weapon swap purely for debuff application.
Best Gear and Itemization for Ice Shot Amazon
Ice Shot Amazon uses a Bow and Quiver, which means gearing can become expensive in the deep endgame. Most stat priorities mirror Lightning Arrow builds, with lightning modifiers replaced by cold equivalents.
Key Stat Priorities
Added Cold Damage to Attacks
Increased Cold Damage
Projectile Damage
Critical Strike Chance and Multiplier
Attack Speed
Cold Penetration
Since additional projectiles on bows are no longer available, Fork and projectile scaling are essential for clear speed.
Defensive Gear Choices
High Evasion on Helmet and Body Armour
Hybrid Energy Shield / Evasion if using Subterfuge Mask
Hybrid defenses are strongly recommended if running Stalking Panther
While high-end Path of Exile 2 Items can be costly, Ice Shot scales extremely well with investment. Mid-tier gear comfortably clears maps, while optimized bows and quivers push the build into boss-melting territory. Many players upgrade gradually buying Path of Exile 2 Currency, prioritizing weapon damage and crit first.
Passive Tree and Ascendancy Setup
The Ice Shot Amazon passive tree is intentionally similar to Lightning Arrow, minimizing respec requirements.
Passive Tree Focus
Projectile Damage
Cold Damage
Attack Speed
Movement Speed
If you want faster mapping early, prioritize movement speed nodes. Damage can be scaled later as gear improves.
Ascendancy Progression
1. Predatory Instinct - Enables Reveal Weakness for massive Rare and Unique damage
2. Critical Strike Nodes - Taken in Act 3 for consistency
3. Penetrate - Unlock after Act 4 for strong elemental scaling
4. Stalking Panther - Flexible final node for survivability and mobility
This Ascendancy path delivers strong early power and excellent late-game scaling.
Final Thoughts
The Ice Shot Amazon is one of the most satisfying ranged builds in Path of Exile 2, combining fast clears, reliable crowd control, and devastating burst damage. It's an excellent choice for players who enjoy Lightning Arrow-style gameplay but want a fresh experience built around Freeze mechanics, shatter explosions, and buy POE 2 Mirror of Kalandra precision boss damage windows.
