q os parece esta suspension? tiene buena pinta no por 350¤
This is a Gaz adjustable suspension kit for Peugeot 106 all models (1991 +) and Citroen Saxo 1996 onwards.
The kit has two front adjustable damping inserts, two rear adjustable dampers and two front -40mm lowering springs.
Every Gaz unit is fully tested and dispatched with an individual dynometer report.
Made to accredited ISO9001 standard and supplied with a 2 year unlimited mileage warranty.
Gazzmatic International Ltd. are a TUV approved company.
Gaz shock absorbers strike the ultimate balance between comfort and performance roadholding.
Ideal for fast road or track day use.
Gaz shock absorbers guarantee to improve the looks and handling of your car.
Fully rebuildable and servicable.
Gaz units are provided with an on car multi point adjustment facility that alters bump and rebound settings by a single control knob on the side of the unit. The inserts are fitted with a top adjuster that alters rebound settings only.
They have zinc plated bodies for maximum protection against corrosion.
Made in England.
y tambien e esacontrado esta Pues 250 mas portes, tiene cantidad por si alguein quiere.
http://my.frooition.com/070481/images/U ... gshop2.jpg
HOTTUNING FULL COIL OVER KIT
WITH A 2 YEARS WARRANTY
This is a full coilover kit for the front and rear of your vehicle. Kit will fit:
COIL OVER CITROEN SAXO ALLE ENGINE
2 X FRONT SHOCK ABSORBER AND 2X ADJUSTABLE SPRINGS REAR 2X SHOCKABSORBER AND THE TORSION BAR YOU CAN ADJUST YOURSELFS
Coilover Specifications:
HOTTUNING coilovers can be raised or lowered, from 20mm to 80mm. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. CNC Wound SAE 9254 Racing Springs are used which were found to be the longest lasting spring on the market that showed no tendencies to sag. Spring and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability are used. Extensive Research And Development Went In To Choosing Precisely Matched Spring & Damper Rates Specific To Each Application. The Result Is Outstanding Ride Quality & Incredible Handling Characteristics
This Kit Includes - 2x FRONT COILOVERS 2x REAR COILOVERS/SPRING ADJUSTERS 1x C-SPANNER
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. HOTTUNING , Designed and manufactured for customers who demand the very best!
FAQ:
Is this a complete kit?
Yes this is a complete suspension kit for all four corners of the car
Does this fit my vehicle?
This kit will fit the vehicle listed in the first table above.
Is there a Guarantee?
Yes. This kit is covered by the manufacturer for two years.
What kind of quality is this kit?
This kit is of comparable quality to units offered by Gmax, Pi, FK, Weitec and Jamex. The shocks are approx 30% uprated over standard.
You can get more info on our website or email us
Only SERIOUS BUYERS PLEASE. Only buy you intend to complete the transaction.
FEEL FREE TO CHECK OUT OUR FEEDBACK!! OUR CUSTOMER SERVICE IS #1!!
Check out Our Ebay Store for more suspension/performance components for your vehicle!
Made in England.
FAQ:
Última edición por sergio_rs6 el 27 May 2008, 14:09, editado 2 veces en total.
[center]Saxo VTS 8V
Lo consegui!!! ahora poco a poco dejandolo en condiciones...
Ahora cuando veo saxos los observo y pienso sera alguien del foro¿?
Yo pago cuota para mantener este foro... y tú ??? Socio CSE
Mi saxito aqui lo vereis!!!![/center][center]
[/center]
[/center]
