In the ever-evolving world of Path of Exile, few activities capture the raw intensity and reward structure quite like Delve. Known for its infinite scaling, dangerous encounters, and lucrative rewards, Delve represents one of the most punishing-and profitable-endgame systems in the game. This guide explores a high-investment, endgame Delve build that thrives in extreme depths, focusing on survivability, sustained damage, and currency generation.
Diving Into the Depths POE currency
At the core of this build is high-depth Delve farming-hovering around depth 800 and pushing toward 900+. At these depths, enemies hit harder, scale faster, and punish mistakes instantly.
However, the rewards-particularly from Abyssal nodes and fossil farming-become extremely valuable.
One of the major sources of income in this setup comes from Hollow Fossils, which can drop in abundance in specific Abyssal Delve nodes. Combined with the sheer density of encounters, this creates a "currency printing" environment where efficiency equals profit.
But surviving at these depths isn't trivial. It requires a carefully tuned combination of defensive layers, regeneration mechanics, and damage scaling-all working in harmony.
Core Defensive Philosophy: Survive First, Everything Else Second
This build embraces a layered defense system rather than relying on a single mechanic. The goal is simple: absorb, recover, and mitigate damage consistently.
Key Defensive Mechanics
High Life Regeneration: The build can regenerate upwards of 4,000+ life per second passively, with spikes reaching 15,000-20,000 life per second under pressure.
Damage Conversion: Physical damage is partially converted to fire, reducing the impact of incoming hits.
Barrier System (Bound Flesh): A key defensive addition, this mechanic builds barriatic tension as life is spent (due to Blood Magic). When a large hit lands, this tension absorbs and mitigates damage.
Petrified Blood + Progenesis: These combine to delay and smooth incoming damage, effectively acting as a second life pool.
Stun-Based Recovery Loop: With mechanics tied to being stunned, the build intentionally leans into controlled damage intake to trigger recovery systems.
This layered approach ensures that even in high-depth Delve, the character can withstand heavy bursts of damage-though it is important to note that it is not truly immortal. Mistakes or extreme burst damage can still result in death.
The Power of Gear: Scaling Into Endgame
The gear in this build reflects its high-budget nature, sitting at an estimated 350 Divine Orbs investment.
Major Gear Highlights
Mageblood: One of the most powerful utility items in Path of Exile, enabling near-permanent flask uptime. This dramatically improves movement speed, defenses, and overall fluidity.
Progenesis: Acts as a defensive multiplier, spreading incoming damage over time and synergizing with regeneration.
Anger Aura via Aul's Uprising: Removes reservation cost, freeing up resources for other defensive layers while boosting fire damage.
Dark Seer (Upgraded): A version with +2 maximum life per level, significantly boosting the life pool.
Valyrium Ring: Converts energy shield-based stun thresholds into life-based ones, ensuring the build remains stun-viable for its mechanics.
These items, combined with carefully chosen flasks-such as Quartz, Quicksilver, Granite, and Ruby-create a system where survivability and mobility are tightly intertwined.
The Flask Engine: Constant Uptime, Constant Power
Flasks are a critical component of this build, especially with Mageblood.
The setup typically includes:
Quicksilver Flask: Movement speed
Quartz Flask: Phasing and dodge
Granite Flask: Armor boost
Ruby Flask: Fire resistance and mitigation
Utility Flask with rarity or additional bonuses
Because Mageblood provides near-permanent flask uptime, these bonuses effectively become permanent stat buffs-greatly enhancing both defense and speed.
Skill Setup: The Heart of the Damage Engine
This build revolves around a Cast when Stunned (CwS) mechanic, allowing abilities to auto-trigger in response to incoming hits.
Core Skill Synergies
Firestorm of Pelting: Main damage source, enhanced with support gems.
Blazing Salvo + Detonate Dead: Additional scaling through corpse interactions and explosive damage.
Cremation: Provides sustained fire damage zones.
Wave of Conviction + Flammability: Applies exposure and curses to weaken enemies.
Righteous Fire: Adds passive burning damage, scaling with regeneration.
Vitality Aura: Boosts life regeneration significantly.
This setup ensures that while the player is actively taking hits, they are also automatically retaliating with layered offensive pressure.The Intelligence Problem: Solved with Brute Force
One of the challenges in this build was meeting intelligence requirements. Instead of optimizing through complex gear swaps, the solution was straightforward:
Convert passive nodes into intelligence
Use Brute Force Solution jewel
This approach provided a significant boost-around 50 intelligence-solving gearing constraints without sacrificing efficiency.
Ascendancy and Passive Tree Optimization
The passive tree plays a critical role in maximizing both offense and defense.
Key Changes
Transition from earlier nodes to Bound Flesh, enabling barriatic tension
Removal of redundant nodes to optimize efficiency
Integration of cluster jewels for enhanced scaling
Use of Immutable Force and Bloodnotch for stun recovery synergy
Notable Mechanics
Bloodnotch: Recovers a portion of damage taken from stunned hits as life
Immutable Force: Enhances stun and block recovery
Agnostic: Ensures energy shield remains at zero, enabling consistent stun mechanics
These mechanics combine to create a feedback loop where taking damage directly contributes to survival.
The Role of Stun: Turning Weakness into Strength
A defining feature of this build is its relationship with stun mechanics.
Normally, being stunned is a disadvantage. However, in this setup, it becomes a core engine:
Stun triggers Cast when Stunned
Cast when Stunned activates offensive skills
Stun damage is partially recovered as life
This transforms incoming damage into a source of both defense and offense-a hallmark of advanced Path of Exile builds.
The Damage Engine: Fire and Explosions Everywhere
Fire is the central damage type in this build, amplified through multiple layers:
Fire penetration
Increased fire damage
Exposure and curses
Burning damage scaling
Ignites and proliferation
Enemies are often affected by multiple overlapping effects, ensuring rapid clear even in dense Delve environments.
Bossing Adjustments: Tactical Swaps
While this build excels in mapping and Delve farming, bossing requires slight adjustments.
Recommended Swap:
Replace Polaric Devastation with Hateful Accuser
Use Penance Mark
This setup allows enemies to spawn minions that trigger the build's stun-based mechanics, ensuring consistent skill activation even in single-target scenarios.
Limitations: Not Invincible
Despite its power, the build is not without flaws:
Can still die to extreme burst damage
Not designed as a pure boss killer
Requires significant investment
Relies on precise mechanical interactions
However, within its intended use-Delve farming and currency generation-it performs exceptionally well.
Final Thoughts: A Currency-Printing Juggernaut
This build represents the pinnacle of endgame Delve farming in Path of Exile. It combines:
Extreme regeneration
Complex defensive layering
Automated damage output
High mobility and flask uptime
All of this results in a character capable of handling some of the most dangerous content in the game while generating substantial currency through efficient farming buy POE orbs.
At its core, the build embodies a fundamental principle of Path of Exile: turning challenges into advantages. By leveraging stun mechanics, life spending, and damage mitigation systems, it transforms incoming danger into sustained power.
Key Changes
Notable Mechanics
Fire penetration
Exposure and curses
Recommended Swap:
Use Penance Mark
